Use a decimal value representation to implement a permit/deny designation for a packet. The command set for IP ACLs provides the hexadecimal values for each listed EtherType. Use the decimal equivalent of the EtherType listed for any other EtherType.deny [<NETWORK-SERVICE-ALIAS-NAME>|dns-name|icmp|ip|proto|tcp|udp]
deny <NETWORK-SERVICE-ALIAS-NAME> [<SOURCE-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|
from-vlan <VLAN-ID>|host <SOURCE-HOST-IP>] [<DEST-IP/MASK>|any|host <DEST-HOST-IP>|
<NETWORK-GROUP-ALIAS-NAME>] (log,mark [8021p <0-7>|dscp <0-63>],rule-precedence <1-5000>)
{(rule-description <LINE>)}
         deny dns-name [contains|exact|suffix]
deny dns-name [contains|exact|suffix] <WORD> (log,rule-precedence <1-5000>)
         deny icmp [<SOURCE-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|from-vlan <VLAN-ID>|
host <SOURCE-HOST-IP>] [<DEST-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|host <DEST-HOST-IP>]
(<ICMP-TYPE> <ICMP-CODE>,log,rule-precedence <1-5000>) {(rule-description <LINE>)}
         deny ip [<SOURCE-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|from-vlan <VLAN-ID>|
(log,rule-precedence <1-5000>) {(rule-description <LINE>)}
         deny proto [<PROTOCOL-NUMBER>|<PROTOCOL-NAME>|eigrp|gre|igmp|igp|ospf|vrrp]
[<SOURCE-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|from-vlan <VLAN-ID>|host <SOURCE-HOST-IP>]
[<DEST-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|host <DEST-HOST-IP>] (log,rule-precedence <1-5000>)
         deny [tcp|udp] [<SOURCE-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|from-vlan <VLAN-ID>|
host <SOURCE-HOST-IP>] [<DEST-IP/MASK>|<NETWORK-GROUP-ALIAS-NAME>|any|eq <SOURCE-PORT>|
host <DEST-HOST-IP>|range <START-PORT> <END-PORT>] [eq [<1-65535>|<SERVICE-NAME>|bgp|dns|ftp|
ftp-data|gopher|https|ldap|nntp|ntp|pop3|sip|smtp|ssh|telnet|tftp|www]|range <START-PORT> <END-PORT>]
         | <NETWORK-SERVICE-ALIAS-NAME> | Applies this deny rule to packets based on service protocols and ports
                        specified in the network-service alias
 A network-service alias defines service protocols and ports to match. When used with an ACL, the network-service alias defines the service-specific components of the ACL deny rule. Note: For more information on
                           configuring network-service alias, see alias.
| <SOURCE-IP/MASK> | Specifies the source IP address and mask (A.B.C.D/M) to match. Packets, matching the service protocols and ports specified in the network-service alias, received from the specified network are dropped. |
| <NETWORK-GROUP-ALIAS-NAME> | Applies a network-group alias to identify the
                        source IP addresses. Packets, matching the service protocols and ports
                        specified in the network-service alias, received from the addresses
                        identified by the network-group alias are dropped.
 A network-group alias defines a single or a range of addresses of devices, hosts, and networks. When used with an ACL, the network-group alias defines the network-specific component of the ACL rule (permit/deny).  |
| any | Specifies the source as any source IP address. Packets, matching the service protocols and ports specified in the network-service alias, received from any source are dropped. |
| from-vlan <VLAN-ID> | Specifies a single VLAN or a range of VLANs as
                        the match criteria. Packets, matching the service protocols and ports
                        specified in the network-service alias, received from the specified VLAN(s)
                        are dropped.
 Note: Use this option with WLANs and port ACLs.
| host <SOURCE-HOST-IP> | Identifies a specific host (as the source to
                        match) by its IP address. Packets, matching the service protocols and ports
                        specified in the network-service alias, received from the specified host are
                           dropped.
| <DEST-IP/MASK> | Specifies the destination IP address and mask (A.B.C.D/M) to match. Packets, matching the service protocols and ports specified in the network-service alias, addressed to the specified network are dropped. |
                         any  |
                     Specifies the destination as any destination IP address. Packets, matching the service protocols and ports specified in the network-service alias, addressed to any destination are dropped. |
| host <DEST-HOST-IP> | Identifies a specific host (as the destination to
                        specified in the network-service alias, addressed to the specified host are
                           dropped.
                         Applies a network-group alias to identify the destination IP addresses. Packets, matching the service protocols and ports specified in the network-service alias, destined for the addresses identified by the network-group alias are dropped.
                         log  |
                     Logs all deny events matching this entry. If a source and/or destination IP address is matched (i.e. if any specified type of packet is received from a specified IP address and/or is destined for a specified IP address), an event is logged. |
| mark [8021p <0-7>| dscp <0-63>] |
                         Specifies packets to mark
| rule-precedence <1-5000> rule-description <LINE> | The following keywords are recursive and common to all of the above
                           parameters:
         | dns-name | Applies this deny rule to packets based on dns-names specified in the network-service |
| contains | Matches any hostname which has this DNS label. (for example, *.test.*) |
| exact | Matches an exact hostname as specified in the network-service |
| syffix | Matches any hostname as suffix (for example, *.test) |
| <WORD> | Identifies a specific host (as the source to match) by its domain name. Packets, matching the service protocols and ports specified in the network-service alias, received from the specified host are dropped. |
| log | Logs all deny events matching this dns entry. If a dns-name is matched an event is logged. |
                           parameters:
deny icmp [<SOURCE-IP/MASK>|<NETWORK-GROUP-NAME>|any|from-vlan <VLAN-ID>|
host <SOURCE-HOST-IP>] [<DEST-IP/MASK>|<NETWORK-GROUP-NAME>|any|host <DEST-HOST-IP>]
         | icmp | Applies this deny rule to Internet Control Message Protocol (ICMP) packets only |
| <SOURCE-IP/MASK> | Specifies the source IP address and mask (A.B.C.D/M) to match. ICMP packets received from the specified sources are dropped. |
                        source IP addresses. ICMP packets received from the addresses identified by
| any | Specifies the source as any IP address. ICMP packets received from any source are dropped. |
                        the match criteria. ICMP packets received from the VLANs identified here are
                           dropped.
                        match) by its IP address. ICMP packets received from the specified host are
                           dropped.
| <DEST-IP/MASK> | Specifies the destination IP address and mask (A.B.C.D/M) to match. ICMP packets addressed to specified destinations are dropped. |
| <NETWORK-GROUP-ALIAS-NAME> | Applies a network-group alias to identify the destination IP addresses.
                        ICMP packets destined for addresses identified by the network-group alias
                        are dropped.
| any | Specifies the destination as any IP address. ICMP packets addressed to any destination are dropped. |
                        match) by its IP address. ICMP packets addressed to the specified host are
                           dropped.
| <ICMP-TYPE> | Defines the ICMP packet type For example, an ICMP type 0 indicates it is an ECHO REPLY, and type 8 indicates it is an ECHO.  |
| <ICMP-CODE> | Defines the ICMP message type For example, an ICMP code 3 indicates "Destination Unreachable", code 1 indicates "Host Unreachable", and code 3 indicates "Port Unreachable." Note: After specifying the
                           source and destination IP address(es), the ICMP message type, and the
                           ICMP code, specify the action taken in case of a match.
| log | Logs all deny events matching this entry. If a source and/or destination IP address is matched (i.e. a ICMP packet is received from a specified IP address and/or is destined for a specified IP address), an event is logged. |
                           parameters:
         | ip | Applies this deny rule to IP packets only |
| <SOURCE-IP/MASK> | Specifies the source IP address and mask (A.B.C.D/M) to match. IP packets received from the specified networks are dropped. |
| <NETWORK-GROUP-ALIAS-NAME> | Applies a network-group alias to identify the source IP addresses. IP
                        packets received from the addresses identified by the network-group alias
                        are dropped.
| any | Specifies the source as any IP address. IP packets received from any source are dropped. |
| from-vlan <VLAN-ID> | Specifies a single VLAN or a range of VLANs as the match criteria. IP
                        packets received from the specified VLANs are dropped.
| host <SOURCE-HOST-IP> | Identifies a specific host (as the source to match) by its IP address.
                        IP packets received from the specified host are dropped.
| <DEST-IP/MASK> | Specifies the destination IP address and mask (A.B.C.D/M) to match. IP packets addressed to the specified networks are dropped. |
| any | Specifies the destination as any IP address. IP packets addressed to any destination are dropped. |
| host <DEST-HOST-IP> | Identifies a specific host (as the destination to match) by its IP
                        address. IP packets addressed to the specified host are dropped.
                        packets destined for addresses identified by the network-group alias are
                           dropped.
| log | Logs all deny events matching this entry. If a source and/or destination IP address is matched (i.e. a IP packet is received from a specified IP address and/or is destined for a specified IP address), an event is logged. |
                           parameters:
         | proto | Configures the ACL for additional protocols Additional protocols (other than IP, ICMP, TCP, and UDP) must be configured using this parameter  |
| <PROTOCOL-NUMBER> | Filters protocols using their Internet Assigned Numbers
                           Authority (IANA) protocol number
| <PROTOCOL-NAME> | Filters protocols using their IANA protocol name
| eigrp | Identifies the Enhanced Internet Gateway Routing Protocol
                        (EIGRP) protocol (number 88) EIGRP enables routers to maintain copies of neighbors‘ routing tables. Routers use this information to determine the fastest route to a destination. When a router fails to find a route in its stored route tables, it sends a query to neighbors who in turn query their neighbors till a route is found. EIGRP also enables routers to inform neighbors of changes in their routing tables.  |
| gre | Identifies the General Routing Encapsulation (GRE) protocol
                        (number 47) GRE is a tunneling protocol that enables transportation of protocols (IP, IPX, DEC net, etc.) over an IP network. GRE encapsulates the packet at the source and removes the encapsulation at the destination.  |
| igmp | Identifies the Internet Group Management Protocol  (IGMP)
                        protocol (number 2) IGMP establishes and maintains multicast group memberships to interested members. Multicasting allows a networked computer to send content to multiple computers who have registered to receive the content. IGMP snooping is for listening to IGMP traffic between an IGMP host and routers in the network to maintain a map of the links that require multicast streams. Multicast traffic is filtered out for those links which do not require them.  |
| igp | Identifies any private internal gateway (primarily used by CISCO for
                        their IGRP) (number 9) IGP enables exchange of information between hosts and routers within a managed network. The most commonly used interior gateway protocol (IGP) protocols are: Routing Information Protocol (RIP) and Open Shortest Path First (OSPF).  |
| ospf | Identifies the OSPF protocol (number 89) OSPF is a link-state IGP. OSPF routes IP packets within a single routing domain (autonomous system), like an enterprise LAN. OSPF gathers link state information from neighbor routers and constructs a network topology. The topology determines the routing table presented to the Internet Layer which makes routing decisions based solely on the destination IP address found in IP packets.  |
| vrrp | Identifies the Virtual Router Redundancy Protocol  (VRRP)
                        protocol (number 112) VRRP allows a pool of routers to be advertized as a single virtual router. This virtual router is configured by hosts as their default gateway. VRRP elects a master router, from this pool, and assigns it a virtual IP address. The master router routes and forwards packets to hosts on the same subnet. When the master router fails, one of the backup routers is elected as the master and its IP address is mapped to the virtual IP address.  |
| <SOURCE-IP/MASK> | Specifies the source IP address and mask (A.B.C.D/M) to match. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from the specified sources are dropped. |
                        Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from the sources
                        defined in the network-group alias are dropped.
| any | Specifies the source as any IP address. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from any source are dropped. |
                        Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) received from the VLANs
                        identified here are dropped.
                        host are dropped.
| <DEST-IP/MASK> | Specifies the destination IP address and mask (A.B.C.D/M) to match. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) addressed to the specified destinations are dropped. |
| any | Specifies the destination as any IP address. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) addressed to any destination are dropped. |
                        address. Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) addresses to the
                        Packets (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) addressed to the destinations
                        identified in the network-group alias are dropped.
                           the source and destination IP address(es), specify the action taken in
                           case of a match.
| log | Logs all deny events matching this entry. If a source and/or destination IP address is matched (i.e. a packet (EIGRP, GRE, IGMP, IGP, OSPF, or VRRP) is received from a specified IP address and/or is destined for a specified IP address), an event is logged. |
                           parameters:
         | tcp | Applies this deny rule to TCP packets only |
| udp | Applies this deny rule to UDP packets only |
| <SOURCE-IP/MASK> | This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Specifies the source IP address and mask (A.B.C.D/M) to match. TCP/UDP packets received from the specified sources are dropped.  |
| <NETWORK-GROUP-ALIAS-NAME> | This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Applies a network-group alias to identify the source IP addresses. TCP/UDP packets received from the sources defined in the network-group alias are dropped.
 After specifying the source and destination IP address(es), specify the action taken in case of a match.  |
| any | This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Specifies the source as any IP address. TCP/UDP packets received from any source are dropped.  |
| from-vlan <VLAN-ID> | This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Specifies a single VLAN or a range of VLANs as the match criteria. TCP/UDP packets received from the VLANs identified here are dropped.
                        TCP/UDP packets received from the specified host are dropped.
| <DEST-IP/MASK> | This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Sets the destination IP address and mask (A.B.C.D/M) to match. TCP/UDP packets addressed to the specified destinations are dropped.  |
| any | This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Specifies the destination as any destination IP address. TCP/UDP packets received from any destination are dropped.  |
| eq <SOURCE-PORT> | Identifies a specific source port
                        address. TCP/UDP packets addressed to the specified host are dropped.
| <NETWORK-GROUP-ALIAS-NAME> | This keyword is common to the ‘tcp‘ and ‘udp‘ parameters. Applies a network-group alias to identify the destination IP addresses. TCP/UDP packets destined to the addresses identified in the network-group alias are dropped.
| range <START-PORT> <END-PORT> | Specifies a range of source ports
| eq [<1-65535>| <SERVICE-NAME>| |bgp|dns|ftp| ftp-data|gopher| https|ldap|nntp|ntp| pop3|sip|smtp| ssh|telnet| tftp|www] | Identifies a specific destination or protocol port to match
| range <START-PORT> <END-PORT> | Specifies a range of destination ports
| log | Logs all deny events matching this entry. If a source and/or destination IP address or port is matched (i.e. a TCP/UDP packet is received from a specified IP address and/or is destined for a specified IP address), an event is logged. |
| rule-precedence <1-5000> rule-description <LINE> | The following keywords are recursive and common to all of the above:
Use this command to deny traffic between networks/hosts based on the protocol type selected in the access list configuration. The following protocols are supported:
The last ACE (access control entry) in the access list is an implicit deny statement.
Whenever the interface receives the packet, its content is checked against the ACEs in the ACL. It is allowed or denied based on the ACL configuration.
The log option is functional only for router ACL‘s. The log option displays an informational logging message about the packet that matches the entry sent to the consolenx9500-6C8809(config-ip-acl-test)#deny proto vrrp any any log rule-precedence 600
         nx9500-6C8809(config-ip-acl-test)#deny proto ospf any any log rule-precedence 650
         nx9500-6C8809(config-ip-acl-test)#show context ip access-list test deny proto vrrp any any log rule-precedence 600 deny proto ospf any any log rule-precedence 650 nx9500-6C8809(config-ip-acl-test)#
Using aliases in IP access list.
The following examples show the usage of network-group aliases:
nx9500-6C8809(config-ip-acl-bar)#permit ip $foo any rule-precedence 10
nx9500-6C8809(config-ip-acl-bar)#permit tcp 192.168.100.0/24 $foobar eq ftp rule-precedence 20
nx9500-6C8809(config-ip-acl-bar)#deny ip $guest  $lab rule-precedence 30
The following examples show the usage of network-service aliases:
nx9500-6C8809(config-ip-acl-bar)# permit $kerberos 10.60.20.0/24 $kerberos-servers log rule-precedence 40
nx9500-6C8809(config-ip-acl-bar)#permit $Tandem 10.60.20.0/24 $Tandem-servers log rule-precedence 50
| no (ipv4-acl) |
                         Removes a specified IP deny access rule  |
| alias |
                         Creates and configures aliases (network, VLAN, service, etc.)  |
